shawn4308
#1 Posted : Thursday, April 24, 2014 3:25:04 PM(UTC)
shawn4308
Frigidaire (Electrolux) dryer started turning its control panel on by itself. It would jump between dryness modes. If you turn it off, it would come back on. Then finally all 4 lights on the side lit up and flashed rapidly.
Could a fault in the rotary dial send bad signals to the control board and cause this. Can any other device send a bad signal to the main circuit board to cause this? Or is it simply a bad circuit board? Model GLGQ2152ES1.
Sara Reeves
#2 Posted : Saturday, March 19, 2016 6:59:43 PM(UTC)
Sara Reeves
Dryer will run for maybe a minute and stops and the lights starts blinking. I have gotten it to reset before. My dog bumps into it and moves it and thats when it starts this. Sometimes all the lights will blink then 888 appears in the little time window. Please help.
Sara Reeves
