HARRY HEN
#1 Posted : Tuesday, October 20, 2009 10:40:06 AM(UTC)
HARRY HEN
lOOKS LIKE A SEAL LEAKING UNDER DRUM, I WANT TO REMOVE DRUM AND AM HAVING TROUBLE DOING SO. DOES THIS DRUM LIFT OUT,I ALREADY REMOVED FRONT AND TOP PANELS AND LOOKS LIKE AGITATOR DOES NOT COME OUT EASY, REMOVED CAP AND SEE NO SCREW. ALSO WANT TO KNOW HOW BIG A JOB TO REPLACE THE SEAL UNDER DRUM
Frank / APP Team
#2 Posted : Tuesday, October 20, 2009 10:56:56 AM(UTC)
Frank / APP Team
Below is a link to the service manual for your washer. It should help you through the entire process.
http://servicematters.co...ary/docs/RS3100007R0.pdf
Drum Removal Help (Washer Repair)
by HARRY HEN 10/20/2009 10:42:48 AM(UTC)
