I have a 8 year old Maytag MDBH945AWW that is leaving food deposits on glasses, mostly in the top rack, but has started leaving it on all dishes in both the top and bottom racks. I've run multiple cleaning cycles with vinegar and commercial cleaners (CLR, dishwasher magic). I've cleaned out the wash arms (top and bottom) with CLR, and removed the lower wash arm and cleaned out debris.
When I cleaned out the debris I noticed a tear in a part, a paper that seemed to be under the filter pit. From looking at a diagram it might be part of the pump filter. If I replace the impeller shoud I also try and replace the pump filter? I don't want to order the part until I have an idea of what I should replace.
Thanks! pblack00
Here are your parts Parts for Maytag MDBH945AWW Dishwasher - AppliancePartsPros.comI do not know what part you are referring to. If you click on a part's picture or description often another page will open with more views of it and often a Q&A section. Perhaps this will help you. Note that if you click on a different view of a part it will enlarge. |
THIS FORUM IS DEAD!!!!!!! |
