Jody ONeill
#1 Posted : Tuesday, October 20, 2009 9:56:00 AM(UTC)
Jody ONeill
I have 2 codes that have come up on my oven panel. E6 and F2.
Can you please tell what is wrong with my double ovens? I would like to have the ovens fixed by Thanksgiving. Thank you, Jody ONeill
#2 Posted : Tuesday, October 20, 2009 10:42:36 AM(UTC)
Your Model Number looks incorrect the following are for a FBD not a RDB.
Replacement parts for WHIRLPOOL RBD305PDT14 | AppliancePartsPros.com
Here is a tech sheet and a service manual
http://www.servicematters.com/d...0Sheet%20-%208302068.pdf
https://secured.whirlpoo...524e76/$FILE/8178007.pdf
Sounds like a keypad problem but could be the control board. Unfortunately I cannot find a pin-out list for the keypad so that you could check it with a meter then if it checks out the control board becomes the prime suspect.
If the below cleaning does not work I would replace the keypad first but it is a bit of a crap shoot or call in a service tech.
Connector Cleaning
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Jody ONeill
#3 Posted : Monday, October 26, 2009 8:46:21 AM(UTC)
Jody ONeill
Hello,
Thank you for your reply. We cleaned the oven this weekend with the contact cleaner. The oven preheated and stayed on for about 20 minutes and then went off. We are going to try and replace the electronic clock control board. Do you think we need to purchase both the control panel and the control board? Thank you very much for you help.
#4 Posted : Monday, October 26, 2009 12:47:48 PM(UTC)
When you say went off, what exactly do you mean re: did just the elements turn off or did the whole unit shut down or something else?
Did the unit come back up or does it still not work?
Cannot really say without answers to the above.
The control panel would be the prime suspect as the keypad should not be able to shut the unit off.
GE oven codes (Oven Repair (including Ranges and Cooktops))
by rgcbuilders@earthlink.net 11/4/2009 7:19:30 PM(UTC)
Kenmore Oven Codes (Oven Repair (including Ranges and Cooktops))
by jobuck488 8/17/2009 10:29:44 AM(UTC)
