when I set to large load water doesn't stop and over fills. I tried to re set to smaller load -doesn't help when in the middle of filling.it does not happen on small or medium settings
Access the tube running from the tub to the water level switch in the console and blow it out, making sure it is clean and free of debris. Then blow into the tube and see if you can determine the water level switch 'clicking'. If so you should be okay, if not you may have to replace the water level switch, but 95% the problem is with the tube.
