Dishwasher stopped working. Impeller disintegrated. Changed impeller, but dishwasher will not start. Checked door switches, float switch. Will turn on, fill with water then click click, and the motor doesn't start and the unit shuts off. The drain pump works fine. Motor spun free, and no problems with continuity on circuits. Capacitor was checked by electrician, and was good. Ran a Field service test, and it came up low current. Changed control panel, but it still comes up with the same fault. What else can I check? How can I check for this current at the motor, and what should I see? Getting really frustrated. :mad: Please help.
