diythatsme
#1 Posted : Tuesday, April 15, 2014 3:37:02 PM(UTC)
diythatsme
F10 message on front panel need to know what it means
#2 Posted : Wednesday, April 16, 2014 3:20:45 AM(UTC)
Parts for Frigidaire FES366ECB Range - AppliancePartsPros.com
F10 looks like a run away temperature error.
Have you tried removing power /unplugging the unit for a couple minutes to see if it will reset?
Could be a bad oven sensor.
Below is a link on it, check out 7, 8, 20 and 21.
http://www.applianceaid.com/ele...-range-repair-topics.php
If the sensor is OK then it could be the control board.
