mj56gt
#1 Posted : Thursday, April 10, 2014 7:32:47 AM(UTC)
mj56gt
I have a Maytag electric dryer (Model #: PYE2000AYW), and the timer has stopped moving for a few months already. When I put the knob in a cycle, it does not move, and the dryer would keep running until I turn the knob back to OFF position. In addition, regardless which cycle I put it (e.g., delicate), it always runs in the regular cycle with normal heat.
How to check if the timer is totally bad? Or should I just replace the timer?
Thanks!
fairbank56
#2 Posted : Thursday, April 10, 2014 9:00:14 AM(UTC)
fairbank56
Groups: Expert
Are you saying that the timer does advance when in a timed dry cycle? Just doesn't advance in auto dry cycles?
Eric
mj56gt
#3 Posted : Thursday, April 10, 2014 9:11:56 AM(UTC)
mj56gt
Eric
Thanks! No, the timer does *not* move at all regardless which cycle I set it in. Also, even if I set the knob in Delicate cycle, the dryer would run as if in Regular cycle.
fairbank56
#4 Posted : Thursday, April 10, 2014 9:34:41 AM(UTC)
fairbank56
Groups: Expert
In that case, you have a faulty timer.
Whirlpool 31001513 Timer - AppliancePartsPros.com
Eric
mj56gt
#5 Posted : Thursday, April 10, 2014 9:46:13 AM(UTC)
mj56gt
Eric
Thanks for the information, Eric! Have a nice day...
Speed Queen Dryer timer not working? (Dryer Repair)
by sarasharp84 5/9/2014 7:06:02 AM(UTC)
Dryer timer not working in Auto or Time Mode (Dryer Repair)
by orange80 12/7/2013 7:54:41 AM(UTC)
dryer timer not working, heats ok (Dryer Repair)
by jmhudgins 1/25/2013 6:31:23 AM(UTC)
Dryer Timer not working properly? (Dryer Repair)
by Adrian Burke 1/22/2013 8:39:45 PM(UTC)
Kenmore 70 Series Dryer timer not working (Dryer Repair)
by bobbydc 2/17/2012 1:49:55 PM(UTC)
