gjp105
#1 Posted : Wednesday, April 9, 2014 8:09:18 AM(UTC)
gjp105
It began with hit start hear it start up then cut off with E24 (error 24) displayed. I troubleshoot and find a small item int the pump out sump and clean it it out and think it will be fixed. NOPE-hit start, hear it drain out water, although there is no water, then you hear a pause and it switch to begin washing but no water came through inlet. It pumps imaginary water for about 30 seconds then cuts off to dispay E24.
There are 2 ways to make it wash: 1. Add water manually-about a gallon, after a few tries it will run until completion. 2.. remove kick plate and manually jiggle the float switch several times, after a few attempts will run until completion.
You say - replace the float switch - YEP, it was replaced, did it fix it, NOPE-hit start and if no action taken on my part of step 1 or 2 above, the result is E24.
Any Ideas?
gjp105
#2 Posted : Wednesday, April 16, 2014 2:45:27 PM(UTC)
gjp105
Anybody? Anybody? Bueller?
gjp105
#3 Posted : Friday, May 2, 2014 4:27:08 AM(UTC)
gjp105
No replies-so I called repair man. He checks it out. Tells me it is the control module (bottom right underneath-not the one in the door) and tells mee it's over 400 dollars. I tell him thanks but I will buy a replAcement. He says they will bill me.
I call bosch to complain how expensive this part is. They tell me that this specefic part has a five year warranty. So now it's s three way arguent between Bosch, a&e repair (sears subcontractor that bosch uses) and me.
Will eventually post how this turns out! Should be fun.
gjp105
#4 Posted : Monday, June 16, 2014 7:31:18 AM(UTC)
gjp105
The repair guy puts on the control panel turns it on and leaves. Shows e24. We call but dispatch advised too far away to return.
A few weeks later different guy same company shows up. Finds a popcorn kernel in drain. Removed and fixes it for the cycles until he leaves. Now e24 again. I just open the door to bypass the e24 for now. Still not fixed
