I've got a small leak in the lower right corner of the door. I've replaced the door seal, checked the 3 torx screws under the lower spray arm, cleaned all the gunk (there was some) from under the lower seal that is on the bottom of the door, checked the foam insulation for dampness.......all concentrated on the lower right corner. I can't get this figured out. Please help!!:(
OK, I just noticed something else that may, or may not make a difference. The seal for the pump (?), about 11 inches in diameter maybe, is kind of "bubbled" up right in front center. Could water be spraying out from under this seal and causing my door leak? Just noticed this after reading a few posts on here. Thanks!!
Here's a picture. Didn't know I could add one. Hope this helps. If you think this is the problem, is there a thread that can tell me hhow to replace it? Thanks again!!:o scottymaker attached the following image(s):
