Fridge is warm and freezer cold. Have defrosted with blow drier several times works fine for about three days and freezes up again.
Remove the rear panel in the freezer and check for continuity the defrost heater and the defrost thermostat (#7 & #3 on the diagram). If there is nothing wrong then replace the Adaptive Defrost Control (#12 on the diagram). - The ADC Part number: AP4010220
