mikeszutu
#1 Posted : Sunday, March 30, 2014 2:51:10 PM(UTC)
mikeszutu
So it turns out that the burning smell came from terminal block. The red wire from the power cable is burn off and the red wire leading from the terminal block to the stove is shorted and burnt. Is the wiring harness for all the wires or just the red one? Is it this part?w10251765
Obsolete wiring harness connector (Washer Repair)
by Mauiman808 6/8/2024 3:18:08 PM(UTC)
Wiring harness clip KitchenAid freestanding ice maker KUIC18NNZS0 (Appliance Parts)
by GADIY 12/5/2023 12:02:09 PM(UTC)
Broken Wire on Door to Body Harness (Microwave Repair)
by epopper 9/24/2023 7:03:46 AM(UTC)
Icemaker Voltage at freezer wire harness (Refrigerator & Freezer Repair)
by mcouvillon 11/1/2022 8:37:12 AM(UTC)
Samsung oven range wiring harness (Oven Repair (including Ranges and Cooktops))
by Guest 10/30/2022 5:50:11 AM(UTC)
Whirlpool ggw9250pl0 - broken resistor on harness...what is it? (Dryer Repair)
by jamessj1 8/23/2021 7:22:56 PM(UTC)
KitchenAid KRSF505ESS01 Wiring harness (Refrigerator & Freezer Repair)
by MysteryAchievement 8/16/2021 11:52:00 AM(UTC)
Whirlpool Duet Washer - Wire broken off connector on harness (Washer Repair)
by Cephalon 1/21/2021 9:33:49 PM(UTC)
How to check washer parts and wire harness for continuity (Washer Repair)
by rebeccaa 4/26/2019 9:09:16 AM(UTC)
GE Hydrowave Harness Fuse (Washer Repair)
by tehach 11/5/2017 11:40:17 AM(UTC)
Harness To Thermometer Control (Dryer Repair)
by mrsjarvis 5/31/2017 10:35:14 AM(UTC)
ribbon cable harness (Refrigerator & Freezer Repair)
by stgabby 6/27/2015 6:16:20 AM(UTC)
Stove Control Board Harness Repair (Oven Repair (including Ranges and Cooktops))
by eek142 3/16/2015 3:36:50 PM(UTC)
no harness connector for lid switch (Washer Repair)
by Tiffany86 3/12/2015 4:03:30 PM(UTC)
Motor wire harness repair (Washer Repair)
by Borney12 3/1/2015 9:13:34 AM(UTC)
