astro46
#1 Posted : Friday, March 21, 2014 11:20:50 AM(UTC)
astro46
This unit is old. over 40 years. Double oven. Bottom oven is working. Top oven, control lights up, but elements don't heat. Instructions say that the top oven should have both broiler (top) and oven (bottom) elements working during preheat. Neither are heating. I have tried setting to "broil", (to eliminate thermostat as problem?) but top element doesn't heat during broil either.
pull out elements and test for continuity? look at something else first?
astro46
#2 Posted : Sunday, March 23, 2014 10:23:07 AM(UTC)
astro46
This oven is probably older than most of the folks on this site; no experience with it. ;-)
