twpcommish
#1 Posted : Thursday, March 20, 2014 7:03:18 PM(UTC)
twpcommish
my dishwasher will fill up with hot water, then instead of moving to
a wash cycle, it drains the water back out. the motor keeps running.
it's not going thru the wash or rince cycles. It does not matter which cycle i start with i tried pot&pans , just rinse , or normal wash. none of
these cycles work. it just fills then empties....any suggestions??
mr_mjsjr
#2 Posted : Friday, March 21, 2014 3:06:15 PM(UTC)
mr_mjsjr
does it pump the water out or does it just drain out? it matters. you can disconnect the drain hose and let it pump into a bucket to know for certain.
twpcommish
#3 Posted : Monday, March 24, 2014 6:21:29 AM(UTC)
twpcommish
I disconnected the hose & ran the dishwasher. It fills up & washes the 1st cycle, pumps the water out, then stops for about 1 minute. Then the motor runs continuously, no water in or out.
