kandpand
#1 Posted : Saturday, March 15, 2014 3:20:06 AM(UTC)
kandpand
Maytag LDE412 dryer was burning wire that goes from the heating element to the high limit switch. Replaced wire and it happened again. Last night I replaced wire and flipped on the breaker and the element starts heating up with the dryer off. I assume the heating element is staying on and burning the wire. What would cause the heating element to stay on?
#2 Posted : Saturday, March 15, 2014 8:08:44 AM(UTC)
Parts for Maytag LDE412 Dryer - AppliancePartsPros.com
Could be that you have a grounded element.
Unplug the unit and both wires at the heating element.
Measure the heating element. They are usually between 8 and 12 ohms.
Now measure from each side of the element to the ground/frame/Neutral, both should be infinite ohms. If not the heater is grounded causing it to be on all the time.
