dustins
#1 Posted : Friday, March 14, 2014 11:03:47 AM(UTC)
dustins
Does anyone know of a replacement part number for the defrost heater on this Maytag? The Maytag part has been discontinued for some time!
Maytag 63001049
thank you so much for your help. I'm not an applicance guy, just a homeowner!
#2 Posted : Saturday, March 15, 2014 1:52:40 AM(UTC)
Measure the length of the heater and note if is glass or solid metal.
Look on line like Amazon to get a universal replacement
#3 Posted : Saturday, March 15, 2014 7:01:40 AM(UTC)
Are you sure it is the heating element?
The reason I ask is that this unit has a thermal fuse inline with the element which is very uncommon.
Below is your heater element.
Part number: AP4073054
Using the squares which should be 1 inch, it looks like it is about 17 inches long.
Here is another heater I found
Part number: AP4067491
Looks like it is just over 16 inches long.
Also if I look up the spec sheet for this unit it also is a 345 watt, 38.3 ohm heater.
So I would try it.
Hopefully it will fit and the leads will be long enough.
You will have to wire it in using wire nuts.
Try to place them so the open end faces down so water cannot get in them.
Some folks like to seal the ends with silicone as an extra protection.
File Attachment(s):
mtb1504.pdf (175kb) downloaded 8 time(s).
defrost heater discontinued (Refrigerator & Freezer Repair)
by Eballer55 7/8/2011 12:31:23 PM(UTC)
