I have a maytag gas dryer. Is making a pretty loud screeching noise While running. I disassembled the dryer and thought maybe it was the Rear roller wheels. I replaced them as well as the bely while I was in There. That didn't stop it. Disassembled again and reached in the blower To turn the motor shaft. That's where it's coming from. My question is, do I need to replace the whole motor? Or is there a bearing/bushing or something I can just replace? Thanks.
Originally Posted by: Rwchet  I have a maytag gas dryer. Is making a pretty loud screeching noise While running. I disassembled the dryer and thought maybe it was the Rear roller wheels. I replaced them as well as the bely while I was in There. That didn't stop it. Disassembled again and reached in the blower To turn the motor shaft. That's where it's coming from. My question is, do I need to replace the whole motor? Or is there a bearing/bushing or something I can just replace? Thanks. MAYTAG DRYER LD69304AAEE
THIS FORUM IS DEAD!!!!!!! |
