This has been a good oven for 14 years. No complaints.
Model KEBS07DWH6
In the last year it has started to restart itself after cooking and being turned off. Sometimes locking one or both doors. This is an intermittent problem. It doenst run long when it does this. Sometimes its less than a minute then at times it will run a minute or two. It concerns me that it could be the cleaning cycle, which we have never used, coming on. I dont know if the lower element is heating when it does this since it is not visible. Only the top element is visible and it does not start glowing when this happens. The oven only does this after baking or broiling.
Thanks for any and all replies.
THIS FORUM IS DEAD!!!!!!! |
