Hi Guys
I was testing a GE Washer and I got a E31. I noticed that is not pumping the water out. I tested and the first time was ok on every part of the test, but did a RINSE AND SPIN circle test and got the water in but did not pump it out and did not spin at all. Also I can hear a humming going on but do not get result. Should I replace the pump? o what you suggest me to do?
GE MODEL #WBVH5300K0WW
Regards,
