AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer start but stops when I release start button
Dry starts but stops when I release the start button
A Model Number may help others help you. There are a number of different methods for keeping a unit on after the Start is released so a Model Number is required. This may help you find it. Model Number Locator |
THIS FORUM IS DEAD!!!!!!! |
What is the part number for the motor relay and what is the cost of the part.
So the motor relay is not located on the motror, but in the top housing. My question there re two relays in the top section with number 23 one is near item 31 the other near itme 25, which one is the motor start up relay.
The heater relay should have Red/White wires going to it. The motor relay should have Pink/Black wires going to it. |
Dryer Repair
