I have a side-by-side GE Profile Artica which is having trouble staying the correct temperature on the freezer side, but the fridge side is operating normally.
The freezer thermostat is set to 0F and the fridge 37F. They're currently at 22F and 41F respectively, and have been for the past week or so. Here are the symptoms:
- Compressor is running normally - The fridge side stays in the 37-41 range - The freezer stays around 20-25 when set to 0F - The fan (evaporator fan?) in the freezer side is running - There is airflow out of the inside vents in the back of the freezer, but not very cold. No frost around vents - The lower back half of the freezer has about half an inch of what I'd call shaved ice stuck to it, very soft. Can be brushed off with fingers.
I assume this indicates some kind of problem with the defrost cycle. If the coils have indeed iced up, it seems like removing the ice from them would only be a temporary bandaid repair until they ice up again. Any advice?
I managed to get the freezer back cover off (which was by far the hardest part, even following a video tutorial) and as expected, the coils were totally iced over. I followed another tutorial to check things with a meter and the heater and defrost timer circuit came up as expected. The thermistors were a little off, reading 13.3k Ohms when they're supposed to be in the 16 area, but the evaporator and lower freezer area thermistor were both similar values while submerged in ice water for a few minutes so either both are okay or both are contributing to the problem.
I went ahead and defrosted the coils with a hair dryer and sealed things back up and temperatures are reading normal again. This issue may have been considerably longer term than I initially thought: I had (what I thought was a separate issue) a problem with the top half of the freezer sometimes getting warm enough that water droplets would condense on the roof of the freezer and food would thaw out sometimes. That problem is now gone.
Anyway, temps are back to normal and have been holding there for the past several days so I'm hopeful just that bit of maintenance is all that will be required.
Just in case anybody else comes across this thread with a similar issue: the problem reappeared, requiring intermittent de-icing of the coils to make things hum along again for a couple of weeks. I re-checked everything and discovered that the evaporator thermistor was way off the correct resistance reading which prevented the defrost heater from ever turning on or at least functioning properly.
I replaced that thermistor and everything has been working smoothly for more than two months now, temperature holding steady and no frost buildup on the back panel of the freezer section
