yellowsir
#1 Posted : Friday, February 28, 2014 8:09:39 AM(UTC)
yellowsir
Hello all...found this great forum and hoping to receive help. So I have a whirlpool dryer model # gec9858eq0, and it does not produce heat anymore. Any ideas where to start would be greatly appreciated. Thanks in advance. I am handy and have a multimeter. I fixed a fuse I believe a year or two ago on this same dryer. So, once I open it I will become familiar fast with it.
fairbank56
#2 Posted : Friday, February 28, 2014 12:34:34 PM(UTC)
fairbank56
Groups: Expert
Unplug dryer, open lower front panel, check continuity of the hi limit thermostat, thermal cutoff (both on heater box), cycling thermostat on blower housing with four wires (not the violet wires), heater coil (8-11 ohms), also check continuity between timer BK and R terminals when timer is on. Report findings.
Eric
#3 Posted : Saturday, March 1, 2014 2:52:44 AM(UTC)
The first thing to check is if the power is OK.
The heating coil requires the full 240 volts, everything else runs off of half the line (120 volts)
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
