Whirlpool Duet Washer - Motor Control Unit (MCU) Part # 8182706 Remove the front lower panel. Tape off the Micro Switch on the lower right. I'm using a FLUKE voltage meter. With the front of the Motor Control Unit open, test the AC Voltage on the motor connector - 5 Pins - Black wires on mine. + Positive probe on the pin, - negative probe on the washer frame. Pin HI MED LOW Stop F 06 # Speed Speed Speed Fail 1 173 149 132 41 41 2 173 154 132 41 41 3 173 149 132 41 41 4 122 124 124 124 122 5 122 124 124 124 122 When the washer is operating properly and the motor is running you will see voltages similar to columns 2 thru 4 When there is a failure (F 06) the voltages will be as in the last column. Usually after the washer cycles OK at least once and things heat up. My symptoms: On my unit flashed the time remaining three different times as it waited for the motor to spin and the Tachometer readings to be sent. Then it beeped and signaled F 06 with the voltages shown. With no voltage the motor was never going to turn. While the unit was flashing the voltages remained as in the last column. Ordered a new MCU ----- We shall see.................... Next Day ...... Installed the new MCU. Washer runs as it should. Old MCU has a problem. A Very Good Repair. Wifey is happy. Shipping was extremely fast. Ordered at 3:30 pm and was at my door at 11:30 am the next day, with regular shipping. Thank you Your kind of service is hard to find in today's world!
That's why those of us who volunteer on this site are happy to do so.
Thanks for your post, it will be very helpful to others
