JimCowan
#1 Posted : Thursday, February 27, 2014 9:52:56 AM(UTC)
JimCowan
I had a power surge and lost several appliances. Had an estimate done and was told my control board on my GE Profile drop in oven was bad. Ordered a new one and installed and it doesn't power up. First time I've tried doing an oven repair so not sure if there's a fuse or something else I need to check on this unit, the cook top works fine.
festeraddams
#2 Posted : Friday, February 28, 2014 6:00:16 PM(UTC)
festeraddams
Well, recheck your wiring, make shure your neutral feed is good as well as your L1/L2 feeds. If Neutral and L1 are good and you still have no power signs to the EOC then you probably need a new one.
