Hi Everybody,
I have a GE side-by-side refrigerator model # GSL25JFTABS. Yesterday morning we had a power outage for about a half hour. When the power came back on, I noticed that the none of the small indicator lights on the water/ice dispenser were on. I opened the refrigerator and the freezer and the interior lights were working in both compartments. Then I realized that I hadn't heard the compressor or fan (I'm not entirely sure which is the noise maker) turn on and it was slowly getting warmer in both compartments.
We moved the food to a spare fridge in the garage and resigned ourselves to the fact that we will have to get this fixed. We didn't call anyone yesterday because we were ok with the food in the other fridge. Last night, I saw that the indicator lights were back on and the refrigerator was running again. For some reason, everything was working again.
That was yesterday. Today we had another power outage for about 45 minutes and when the power returned, the refrigerator did not come back on. Identical symptoms to yesterday (no indicator lights on the dispensers, interior lights work fine, no fan/compressor running). I'm going to check on it again in a few hours to see if it will start again, but this is probably not good. I've done some searching on the internet and i can't find anyone with the same problem.
From my searching, I see that the motherboard may be a problem. Has anyone seen anything like this before?
I'm hoping someone can help. Thanks in advance. :)
Just an update... I woke up this morning and the refrigerator is running again. At some point in the middle of the night, it decided to start working.
Any ideas?
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Model # RF28T5001SR Samsung. Had power outage, not fridge isn't working. Seems like it's staying cool on the inside but no lights are working or any of the electric display gages.
