Washer Wont Start The Start Button Led Light Keeps Blinking
Inside the lower service panel are tech notes that will tell you how to generate diagnostic error codes and test various components.
My best guess is that the door lock mechanism has failed or that the control unit thinks it has failed and thus will not allow the machine to start. So focus first on the door lock and if that checks out go to the main control unit.
