memerson1
#1 Posted : Monday, February 17, 2014 10:03:01 PM(UTC)
memerson1
OK... my washer will run properly until it comes time to spin, it does agitate and drain, just not the final spin. My husband took off the front, back, and control panel, checked the transmission (based off manual and internet research) and hose for clogs. He couldn't find anything, so replaced everything and then it began to work.... for 1 load.... now back to square one. Any advice would be appreciated!
fairbank56
#2 Posted : Tuesday, February 18, 2014 4:49:44 AM(UTC)
fairbank56
Groups: Expert
Run machine in spin with front panel off. Does the motor run? What's going on with the motor pulley, belt and main drive pulley while in spin? If motor is not running, is it humming? You can disconnect one of the wires to the drain pump so that it is quiet while checking for motor noise.
Eric
memerson1
#3 Posted : Thursday, February 20, 2014 11:11:02 AM(UTC)
memerson1
it hums i'll have my husband check it out with what you've said when he gets off work
