I have a Maytag washing machine. The front says Maytag Dependable Care Plus, Heavy duty with 2 speeds and 11 cycles. I think that the model # is LAT 9804AAN or M. It has stopped working and the tub is still full of water. It had started shaking pretty bad per the tenant after I moved it in a few weeks ago. I tried to spin the tub inside the machine, but it would not move by hand. Is there a check-list that I could perform to assess the problem?
Groups: Expert
With washer on and full of water, does timer advance on it's own? If not, set timer to spin. Now will it advance on it's own? If not, probably a lid switch problem. Open control panel to access lid switch. Make sure washer is perfectly level to avoid unbalance conditions.
Eric
