Fluorescent bulb went out. Went to a loal hardware store to get a replacement. Original is Sylvania F18W/133 T8. The replacement I bought looks similar, but the label is: Sylvania F24 T8 CW, 18W 4100K, and the pins look slightly different. Where they meet the metal ends, the old one has a contact that rus the full diameter of the bulb, but on the new one, the contacts are just independent circles around each pin.
I replaced the bulb. it fits, but doesn't light up.
First, did I cheap out and I really do have to by exactly the same one for some mysterious (to me) reason? Second, is there another part I should replace? My understanding is that sometimes the sockets go bad...but I don't know how to check for the problem. All other features of the hood are working fine.
