fasmith
#1 Posted : Monday, February 10, 2014 4:07:55 PM(UTC)
fasmith
I have a GE Profile PFCS1PJXCSS and the fresh food compartment LED light just quit working. There is no power at the light. There is no power on the output side of the transformer assy. The fuse is good. The input power at the transformer is 51 VAC. I would assume it should be 120 VAC, per the transformer markings. The power at the main board for that circuit is also 51 VAC. I have bench tested the transformer by applying 120 VAC, still no output. I'm pretty sure the transformer assay is bad. However, is the input only supposed to be 51 VAC from the main board? How can I bench test the light assay? Any other thoughts?
Thx fasmith
