Bagger75
#1 Posted : Monday, February 10, 2014 2:43:47 PM(UTC)
Bagger75
I replaced the Bellows as I thought this was the source of my leak. Problem not solved. Now I've noticed it fills up to a third of the door height while rinsing. Is it taking to much water during rinsing? That only happens on second rinse cycle. I just ran the rinse/spin to check it's water level on same load and water level doesn't even show on door. Is it normal for different water levels for the same load of clothes, from a quick wash rinse cycle to a drain/rinse cycle?
