I've got a Kenmore Elite OASIS model number 110.28032701 showing an LF (long fill) error code. There is some literature in other websites claiming that the pressure switch would need to be replaced. However I don't find a pressure switch in any parts list for this model. Does anybody know how this can be fixed? Thank you!
Originally Posted by: Miguel*Paredes I've got a Kenmore Elite OASIS model number 110.28032701 showing an LF (long fill) error code. There is some literature in other websites claiming that the pressure switch would need to be replaced. However I don't find a pressure switch in any parts list for this model. Does anybody know how this can be fixed? Thank you! This particular model does not have a seperate pressure switch, the pressure switch is mounted on Part Number: AP4360738 Electronic Control Board. I would check for water pressure problems or debris at the water supply. Check the screens and check the Water Valve Part number AP4929086 the solinoids may be weak or non functioning. Hope this helped. GMBILL
