Hello, Today I noticed water at the back of my washer on the bottom on both the right and left side. I think it may happen during the spin cycle but I'm not sure. Any suggestions on what it could be? Thank you in advance.
I would take off the lower service panel, clean out the pump and inspect the drain hoses to the pump and from the pump outward.
If you cannot see a problem, operate it with the lower service panel off and during the drain cycle you may be able to see where it is leaking from.
Thank you for your response. We took off the access panel and saw that the right shock absorber is broke. We believe that is why it's leaking.
