I have samsung ref mdl# RS2530BSH/XAA it will only get to 22degrees in the freezer and 39 degrees in the refrigerator at the coldest settings. No frost in the freezer and the defrost works just as it should. The refrigerator damper works just fine. The condenser and evaporator fans are operating correctly and the condenser coils are clean. What temps should there be at max setting for both sides and what actually controls those temps?
