oceanfit
#1 Posted : Tuesday, February 4, 2014 10:53:37 PM(UTC)
oceanfit
My dryer makes a klunking sound every complete rotation. Its almost as if the drum is lifting and falling at the shaft. I can turn the drum by hand with ease and still hear the sound. Could this be the assembly-shaft (ball hitch) or the the rear drum bearing? thank you.
GMBILL
#2 Posted : Wednesday, February 5, 2014 2:24:28 PM(UTC)
GMBILL
Front Felt Glide Assembly AP2150497 Upper dryer drum front felt seal with three glides sometimes wear out/off and causes the welded seal in the drumb to thump against the front assembly. Additional part to check is the rear drum bearing kit AP2142648.
#3 Posted : Thursday, February 6, 2014 1:53:37 AM(UTC)
Also check the drum seam.
Sometimes they can split.
