Malumake
#1 Posted : 11 years ago
Malumake
Aloha all,
My oven stopped heating correctly in the middle of baking. The gas range works fine. The electrical heating coil for broiling is working. The thermometer seems to be still reading temp. I hear the clicks for the ignitors, but don't see any sparks or hear/smell any gas in the oven. On power down (unplug) and then power on (plugin) I receive the following::
Code:
[COLOR="Cyan"]KITCHEN-AID[/COLOR]
            [COLOR="Red"]05[/COLOR]
      [COLOR="Cyan"]AM71 UI73 EEKGO-092[/COLOR]
Mahalo in advance!
Malumake
#2 Posted : 11 years ago
Malumake
On 8 Feb. I Narrowed it down to ERC, Spark Module, or gas valve. Pulled ERC and Spark Module, and checked for bulging caps, checked continuity on various transisitors, found no faults. Did the same for the ERC, same results. Got under the oven and tested the solenoids, one was fine the other was not. New gas valve was ordered.
Just received the part, and it works great now.
Please Help!! Whirlpool gas oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Rebetimm 15 years ago
