marin001
#1 Posted : Sunday, February 10, 2008 1:10:40 PM(UTC)
marin001
the inner glass in the oven is cracked, can i still use the oven or should i
just repair first then use it. also since it is the oven can i still use the
stove top????
#2 Posted : Monday, February 11, 2008 12:10:43 PM(UTC)
If there is just a crack but the glass is still in place you can use the oven for cooking. Do not use the self clean until you replace the glass.
The oven door glass does not affect the surface burners at all.
The model number you posted is incorrect and if you need more specific information about the door glass you have to verify the model number and repost it.
