jjandrnow@msn.com
#1 Posted : Thursday, January 30, 2014 2:03:47 PM(UTC)
jjandrnow@msn.com
I believe the noise is coming from the rear drum bearing. I have it disassembled and it appears to be worn.
My question is if I purchase the bearing kit Item number 508 PN AP2619300, does it include all needed parts for the bearing replacement?
Thank you, Rick Smith
#2 Posted : Saturday, February 1, 2014 1:31:12 AM(UTC)
Yes it looks like it contains everything you need.
Take a look at the Q&A section when you click on the part's picture or description.
Since you have it ripped apart you may as well give it an overhaul.
I would check the following for wear etc. and replace them as necessary.
All seals, front drum support glides, the belt and the idler wheel.
Give the interior a good cleaning including the blower wheel.
This is also a good time to check/clean your vent system.
