RegulatorFix
#1 Posted : Thursday, January 30, 2014 6:17:53 AM(UTC)
RegulatorFix
2 off the heating elements of the glass cook top don't work anymore.
Seems like the part number for the elements of my model are (see below).
a) best source to order the parts
b) service manual and/or instructions how to change the elements
Thanks.
15
PART NUMBER: 74009898
16
PART NUMBER: 74008568
Substitution: 12002141
17
Triple element
PART NUMBER: 74011844
18
PART NUMBER: 7406P497-60
Substitution: 7406P497-60
#2 Posted : Friday, January 31, 2014 12:19:33 AM(UTC)
Parts for Maytag MER6875BAF Range - AppliancePartsPros.com
Here is a link to a service manual.
http://appliancejunk.com...wnloads;sa=view;down=376
You will have to join the site and be logged in to be able to download the manual.
Also if you click on a part's picture or description a new page will open with more views and often a Q&A section about that part.
See section 02 for the elements.
If both elements went out at the same time then I would check for a bad connection to the elements.
[COLOR="Blue"]a) best source to order the parts[/COLOR]
I like AppliancePartsPros because they sponsor this forum.
Also they get e very high rating as a part's supplier.
RegulatorFix
#3 Posted : Friday, January 31, 2014 3:11:17 AM(UTC)
RegulatorFix
Excellent!
Thanks.
Doesn't seem complex to take the top off and replace the heating coils.
Should be back in business early next week.
