I have a split unit the a/c works fine started heat up for winter can here thermostat click on which is new but heat never comes on goes straight to a circuit board 624625 (part #) other than that you only have a breaker, transformer andseveral sequencers and limit switch. To me it seems my problem might be in the circuit board. does anybody have a idea on where i can jump around this circuit board to rule out everything else? thanks
is this in a mobile home? is the circuit board in the air handler? is this a heat pump?
