ColdHands
#1 Posted : Sunday, January 26, 2014 8:33:02 AM(UTC)
ColdHands
Kenmore 90 series washer will not run. Pulling on the knob to begin a wash only causes a soft buzzing noise. This happened before and the machine fixed itself the next day, two times, I believe. This always happens during winter (washer room gets cold - as low as 40 in 0 degree weather). I can get what sounds like the drain cycle between wash and rinse to activate, but it doesn't sound quite right -- metallic and clicky. There's no water in the machine to my knowledge.
ColdHands
#2 Posted : Sunday, January 26, 2014 11:00:27 AM(UTC)
ColdHands
It was the cold :o
Thermometer registered 38 F in the room with the W/D. I dropped a little cube heater down inside and ran a space heater in the room. Once it hit 60 F in the room the washer went through all cycles OK.
