guanacux
#1 Posted : Tuesday, January 21, 2014 8:22:15 PM(UTC)
guanacux
My refrigerator stopped cooling a few weeks ago, the fans still works but when I open the rear panel, The right side of it has iced on it (See picture attached[URL="http://i39.************************/bzmu.jpg"][/URL])
I've read this seems to be a defrost issue. I have a voltage meter but have no idea what a defrost looks like or the heater in the fridge but I'm very willing to learn and save myself a few bucks. I'm a computer science engineer, how hard can this be?
Please help!, My food is currently on plastic ice coolers.
Thank you in advance!
guanacux attached the following image(s):
#2 Posted : Wednesday, January 22, 2014 2:42:42 AM(UTC)
If the compressor is warm and vibrating, you have a bad compressor/ refrigerant leak.
guanacux
#3 Posted : Wednesday, January 22, 2014 9:37:14 AM(UTC)
guanacux
I don't hear the compressor vibrating. After I placed a fan to defrost the ice built up (on the picture), I reconnected the fridge last night and I will check if the compressor is hot and see about the temperature. I'm asumming it will be cold when I get there tonight but I might run into the same problems of not defrosting properly.
I will post back my results tonight. If it's hot and vibrating, is it easy to replace?
