Kbywg
#1 Posted : Monday, January 20, 2014 9:52:37 AM(UTC)
Kbywg
Original problem was just no spin. Drained fine. Watched your vid on YouTube and found clutch was worn so got the new one AND a coupler since I had it all apart. The replacement coupler looked better as it has a metal piece where the flat parts are so it won't round. Re assembled all no problem. Test went fine during first cycle it drained and spun but the breaker popped near the end of the spin but I thought it was cuz I was vacuuming up the mess and was plugged into the same circuit. Do reset breaker and started machine again. It filled for the rinse but no agitation, no spin and no drain. Timer ticks away and there is a hum/buzz sound but no action. Siphoned the water out took it all apart again and checked coupler and clutch. All look good. What's up wit dat?
:confused:
Kbywg
#2 Posted : Monday, January 20, 2014 9:56:40 AM(UTC)
Kbywg
Sorry wrong place. Don't know how I posted this to a dishwasher page. Sorry.
