Hi, Both water dispenser and ice maker are not getting any water. Checked water pressure, it is OK. Replaced filter with brand-new. Still no water. As far as I can see, water reaches up to the filter since it gets filled with water and I can see water squirting out whenever I remove and replace the water filter. But when I try to press the dispenser lever, I can only hear water rushing in and then it quiets down and all that I can hear after that is a humming sound like that of a small motor. That's why I believe water goes as far as the filter.
Jess
Found a coiled hose inside the fridge which carries water to both the dispenser and ice maker. Water inside the hose seems frozen. Used kitchen towel soaked in hot water to thaw the water in the coiled hose. After a few minutes, water came out of the dispenser. After a few hours, ice cubes started coming out of the ice maker.
Thanks for the info. Modify message
