repchino
#1 Posted : Thursday, January 16, 2014 5:14:38 AM(UTC)
repchino
Hello!. This is the problem. The past week I note my refrigerator not cooling enough and I found on the wall of the freeze compartment full of ice. took off this wall and defrost all the ice, also clean underneath the refrigerator and it start to work perfect. But now after 5 days is the same thing again, the two fans (the rear one and the one inside the freezer) are working. So can anybody give an idea of what to check.
#2 Posted : Friday, January 17, 2014 2:48:37 AM(UTC)
Look for a hole in the control panel and turn the defrost timer clockwise till the compressor stops. If no defrost action, you most probably have a blown defrost thermostat attached to the top of the evaporator coils.
