Hi, Brand new member here with a dryer problem. I have a Maytag model LDG8420AA that is no longer heating up. The drum is spinning fine and I checked the outdoor vent and there is plenty of air flow. The problem is the air is cold. The dryer has a small access door in front that shows you the gas valve area. I looked in and see that gas valve coils have a pretty thick layer of dryer lint covering them (as do most of the components). When I turn the dryer on I do not see any flame at all. I spoke with Frank at APpro who was very helpful. He said I should look at parts at this link: 05-Gas Valve parts for Maytag LDG8420AAL - AppliancePartsPros.comI have never repaired an appliance before, but the local repair service has a 4 day wait. Depending on the part, I will be comfortable doing this myself. Here are my questions: 1. Is there any chance that all the lint caused a part to fail? 2. Would cleaning out all the lint solve the problem? I know it needs to be cleaned during the repair. I prefer to not disassemble the unit just for cleaning unless it has a chance of resolving the issue. 3. Before trying anything, could I use compressed air to blow the lint off the components? If the dryer is off, is this safe? 4. Since I have no spark or flame, can you tell me which parts need replacing? I watched the video for the gas coil kit here: Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.comThe dryer in the video is slightly different than mine and it seems like I may not need to pull the drum out for this repair. From what I see (and I admit I am new at this), potential parts are: PN AP3094251 Gas Valve Coil Kit $15.95 PN AP3109449 Flat Style Dryer Igniter $18.43 PN AP2910747 Flame Sensor $31.98 Any help would be greatly appreciated! I would like to order the parts today, if possible.
Groups: Expert
Looking through front access panel, with dryer on, you should be able to see a glow from the ignitor. If not, then you need to do some tests with multimeter to figure out the defective part. Do you have a meter and experience using it? You can throw parts at it if you want but that seems like a waste of money and time. Problem could be timer, motor switch, temp switch, cycling thermostat, hi-limit thermostat, radiant sensor, ignitor or a wiring issue. If you do see glow from ignitor and then ignitor glow dims but no gas flame, then gas coils may be faulty.
Eric
Eric,
Sorry for not replying sooner. I do not have a multimeter so I went ahead and hired an appliance repair service. Turns out it was a bad igniter. Total cost was $120 to swap out a $20 part and clean the inside. Now that I watched the repairman open the unit and work inside it, I will feel more comfortable doing this on my own next time (hopefully many years down the road),
