My dishwasher has began leaking at the bottom of the door, I have taken the door panel off and do not see anything that looks odd. The seal around the sides and top of the door looks good. I am not sure where to start. Thank you in advance.
tub gaskets go limp after a while, need to replace. Also some units have 2 small plastic deflectors one on each bottom corner of the tub that go bad as well. They just stick on.
