WHEN i USE THE WATER DISPENSER IT SPRAYS WATER FROM THE SIDE AS WELL AS THE WHOLE
I received a complaint for the same problem on KitchenAid KFIV29PCMS00 water sprays out rather than a straight stream If I find the problem I'll try to remember to post it here
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Yes, zi have the same problem!
