tjstenz
#1 Posted : 18 years ago
tjstenz
I've replaced the water valve and the water level switch. The washer will only run hot water even when the water temp. is on cold.:eek:
ApplianceJunk
#2 Posted : 18 years ago
ApplianceJunk
Make sure the hot and cold hoses did not get switched around.
