the washer fills fine with water but doesn't agitate when advanced to spin cycle it spins out fine. I changed the motor because when I removed the belt the motor didn't come on in agitate and also tried a diff timer I am at a loss help
Groups: Expert
Check the water level pressure switch and pressure hose. That switch is what powers the motor for agitation.
Eric
